[5th Gen : 08+]: Bagged
Old May 3, 2020 | 10:01 PM
Insight mike's Avatar
Insight mike
Default Bagged
Just wanted to share my 2014 Grand Caravan R/T
Old May 17, 2020 | 08:45 AM
spacebar's Avatar
spacebar
Looks great. wheel and tire setup??
Old May 17, 2020 | 09:10 AM
Insight mike
2015 Jeep Grand Cherokee srt8 replicas 20x9. Wrapped in 255/35 tires.
Old May 17, 2020 | 09:23 AM
spacebar's Avatar
spacebar
Any issues with the larger wheels? If you don’t mind, where did you find the clear headlights? Love the build
Old May 17, 2020 | 10:16 AM
IDon'tGiveARam's Avatar
IDon'tGiveARam
I have custom built my intake and as a result I can't leave a stop without spinning the tires. I want to put a much wider tire on when next I need tires. So I also wonder how the 255 width is going, and I will look up the offset on the wheel too because that's important.
Old May 17, 2020 | 01:22 PM
Insight mike
Like this? 😎
Old May 17, 2020 | 01:25 PM
IDon'tGiveARam
Originally Posted by Insight mike
Like this? 😎
NICE! This engine makes up to like 315 horsepower in the charger. they gave us a 31 square inch air box in which the choke off our air supply with in hopes of achieving better mileage. I'm not going to mess with the tune because I'm still under warranty but with the cold air intake in a 4in tube still running from the back of the filter I get a lot of more torque and more importantly a beautiful note when I'm cruising at 2000 RPMs.
Old May 17, 2020 | 02:54 PM
Insight mike
I love my wide tires. No issues at all. I had 255/40 before these. 255/40 is a more proper size, but this time I went shorter sidewall for the new suspension.
Old May 17, 2020 | 03:19 PM
spacebar's Avatar
spacebar
Like this? 😎
any more pics on your build?
Old Jan 22, 2021 | 04:27 PM
BlizzardGC's Avatar
BlizzardGC
Default Like the build
I have a 2016 GC - I have 20" wheels now - will be going to 22's shortly. 22" wheels, 8.5" width, 35mm offset & 255/35/22 rubber bolt right up with no rubbing. I am going to concentrate on exhaust and engine mods vs going down in the weeds. I love the look though. If I can find someone in Oregon to build a true performance exhaust system for me - I will purchase and bolt on all the intake manifold, 80mm tb and 4" cold air intake mods available for the 3.6L
