[5th Gen : 08+]: Can I pull safely 3700lbs with a 2019 DGC sxt with factory hitch?
Old Jun 14, 2020 | 08:06 PM
Sef's Avatar
Sef
Default Can I pull safely 3700lbs with a 2019 DGC sxt with factory hitch?
I want to buy a trailer but the dry weight is 3011lbs and GVWR is 3800lbs and hitch weight is 310lbs.
can I safely tow it with minimal stuff? With my 2019 Dodge Grand Caravan sxt with factory hitch?
Old Jun 15, 2020 | 10:34 AM
Mopar340's Avatar
Mopar340
The manual list equipped with a class III hitch a Grand Caravan can tow a trailer with Max Gross Trailer Weight 3,600 lbs with 2 persons and luggage. The Max Tongue Weight 360 lbs. If your Grand Caravan is equipped with Sto N Go seating the MGTW has to be reduce by 100 lbs 3,500 lbs
Old Jun 15, 2020 | 10:52 AM
Sef's Avatar
Sef
So just keep it loaded at 3500lbs and i should be good? I have two of the same vans, one is a 2019 and the other a 2018.. I was thinking tow with one there and the 0ther back so I wear both transmissions at the same time and can carry more.
Old Jun 15, 2020 | 11:10 AM
Sef's Avatar
Sef
https://www.westernrvcountry.com/pro...-rbd-997915-29
https://www.rvguide.com/specs/palomi...able/147x.html
I was looking at these two.
Can i pull either one?
Old Jun 16, 2020 | 07:15 AM
Mopar340's Avatar
Mopar340
Yeah you should be fine with either of those 2 trailer if you keep within range within the cargo limit. Make sure you've got trans cooler on your vans .
