[5th Gen : 08+]: Brake Torque Specs - 2013 (5th Gen) w/ Heavy Duty Brakes
I have a 2013 Dodge Grand Caravan with the heavy duty (Dual Piston in the front) brakes.
I found the following torque specs, but I think this is for the base model, and I'm not sure if it's the same for the heavy duty brake upgrade.
Can you please confirm:
Front calliper bolt: 150 ft lbs
Rear calliper bolt: 74 ft lbs
Front and rear calliper pins: 26 ft lbs
Front and rear banjo bolts: 35 ft lbs
Can someone please confirm this for me? Thanks in advance!
Last edited by snakedog116; Oct 11, 2020 at 08:30 PM. Reason: Found on Haynes.com that the front caliper bolt for the 2013 and older is 150ft lbs instead of 125
The banjo bolts on the heavy duty brakes are torqued less than the regular brakes?
or are you saying that the spec I found on the regular banjo bolts is wrong as well?
I found these specs on this forum and on the Haynes website.
I caved and bought the Haynes manual.
You were right, it is 18 ft lbs for the banjo bolts.
not sure where I got my number.
Haynes doesn’t say anything different for regular vs heavy duty brakes.
Even for banjo bolts on HD pickups meant for towing and hauling, 35 ft-lbs is pushing it - I think the highest spec I’ve seen is 30 ft-lbs but that was on an early 90’s pickup. I’m not saying they don’t exist today but I think most banjo bolts anymore are in the 20 ft-lbs range no matter what they’re on.
Keep in mind, MOST banjo bolts are made of brass or aluminum alloy - it doesn’t take much to strip the threads on those soft metals. The spec is meant to provide the maximum clamping force the bolt can provide, and even though 18 ft-lbs may not seem like a lot, you’d be surprised how much effort it takes to reach 18 ft-lbs if all you were using is a standard length combination wrench.
