[4th Gen : 01-07]: Am I screwed? Coolant/Heat issues
Old Nov 15, 2020 | 08:44 PM
Krystyn's Avatar
Krystyn
Default Am I screwed? Coolant/Heat issues
So first let me preface this with telling you that I am homeless and I live in my van and I was currently driving to the Southwest for the winter.
Whike I was driving I turned on my heat and the heater came on for about 15 seconds and then it became cool. I turned off the heat and turned it back on and the same thing happened, first it was hot and then it got cool about 15 seconds later. Then I noticed my engine temperature, while not overheating, wad higher than usual. I pulled into a Walmart and noticed some fluid around my engine block near where the pulleys are. It wasn't a lot of fluid but it was definitely there. I have attached a picture. So I am guessing, and hoping that this is my water pump. Would that be right to assume? If it is my water pump, any ideas on how much that cost to get fixed?
Would there be different symptoms if this was my head gasket say?
Thanks for any info.
Old Nov 16, 2020 | 08:52 AM
Krystyn's Avatar
Krystyn
So I found a mechanic and will be here for a few hours before he looks at it. Any advice to help me not get screwed because I have little money to spare would be appreciated.
Old Nov 18, 2020 | 09:29 PM
Krystyn's Avatar
Krystyn
Well it turned out to only be a heater hose period cost me $40.
