[5th Gen : 08+]: 5th gen caravan brake noise
I was wondering if someone on here could help me out? I have a 2016 caravan sxt and I have a weird brake noise that comes and goes. Once in awhile when braking it sounds like my brakes are wet in all types of weather heat, rain , snow . There is no way to really describe the noise other than it sounds like they are wet, and its not the noise of rust being scraped off the rotors either. Ive replaced the front brakes and lubed up the sliders myself and then started to have this problem so i took it to the dealer to make sure i put everything back together correctly. They checked it out they said I had but the noise was still there so the dealer replaced the pads under warranty apparently some of the magnetti marrelli pads had issues. So they did that noise is still there and my rear pads and rotors have been done as well by the dealer. Ive checked everything on the front end i can think of and found nothing. Hopefully someone has an answer or suggestion for me.
