[5th Gen : 08+]: 2011 AC problem
Old Sep 5, 2021 | 10:24 PM
uccoskun's Avatar
uccoskun
Default 2011 AC problem
Hello All:
I have a 2011 Grand Caravan. AC stopped working suddenly.
Now I found a puzzle.
My AC clutch engages but the radiator fan does not come on. Even on the highway, I do not get any cold air in the cabinet. I checked the pressure, it reached 75psi before I chaged it to 150 psi on the high side with some 134a.
First, I looking for an answer why my radiator fan does not turn on?
If I short the low side relay, the fan turns on. I did not try to high fan relay. "
Second, why I do not get any cold air on the front and back AC if compressor works.
Thank you,
Old Sep 8, 2021 | 04:05 PM
DodgeCares's Avatar
DodgeCares
Originally Posted by uccoskun
Hello All:
Thank you,
Hi uccoskun,
We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support via private messages.
Rob
Dodge Cares
