[5th Gen : 08+]: 2015 T&C Transmission cooler lines
Old Feb 18, 2022 | 01:06 AM
Dan400Man's Avatar
Dan400Man
Default 2015 T&C Transmission cooler lines
One of the two lines is leaking. Are either lines under pressure when the vehicle is off? I found a video to replace these at
and it looks pretty simple. Any caveats doing this repair?
Should I stick with the Mopar part or the Dorman 624284? Dorman has a limited lifetime warranty, Mopar is 24 months.
Mini-rant: Unbelievable that a 7-year old vehicle with 100k miles has this issue. I run my cars until they die, 20+ years, 300+k miles, but this is the first time I've ever had transmission cooler lines leak.
Old Feb 18, 2022 | 01:11 AM
wheily's Avatar
wheily
they should be under pressure cant rember how much thothey are in and out..as for mopar or dorman part id go with mopar as less chance of it not fitting/working wright but than again id probably make my own and then complain when it failed lol
