[General]: Centre EVIC screen issue
Old Mar 6, 2022 | 05:07 PM
bobr56's Avatar
bobr56
Default Centre EVIC screen issue
Our 2020 Caravan started having display issues with the center display. When the numbers displayed for the speed they would display in sections, instead of a complete 5 it displays each bar that makes a 5 slowly. Also the speed display started being sluggish so as you increase speed the numbers don't change quickly. I took to the dealer and they advised that this happens with all Caravans that have an EVIC screen but it didn't stop them from charging me to check it out! I have no other experience with this model and wonder if anyone else has this issue? Friends that have this feature with other makes don't have this issue so I guess this is a quality issue with Chrysler? Also the dimmer switch for the dash lights is finicky, sometimes can't find a spot where the lights aren't either too bright or too dim. Have driven over rough roads and have the dash lights flicker on/off, again dealer finds nothing wrong! Are these common issues with the Dodge Caravan? thanks for any info
