[4th Gen : 01-07]: Heater return hose
Old Aug 10, 2022 | 02:49 PM
sgb77's Avatar
sgb77
Default Heater return hose
Hello everybody,
I am trying to fix my old 2005 Caravan, it has the 3.8L engine, so keeping repairs low budged is my top priority in this case.
My heater return hose, which runs under the engine and goes into the water pump, but the way the engine is positioned might be the side, not sure.. has a hole on it and need to repair it. Not sure if it is repairable, other than soldering the hole shut, but that might be too much work, but I'm open to suggestions.
My other option is to buy a replacement, but $80 for an old car is kind of crazy..
So, I went to rockauto and tried to search for the piece, but I'm a little confused, because there are two heater return hose and are priced widely apart, they are both listed under the 3.8L engine, so not sure if the cheaper one is the same one as the other one.
If someone can help me figure out which one I would need to purchase, so I don't order the wrong part, it will be greatly appreciated.
https://www.rockauto.com/en/moreinfo...sn=906&jsn=906
https://www.rockauto.com/en/moreinfo...t=6892&jsn=909
https://www.rockauto.com/en/catalog/...ater+hose,6892
Thanks for any help..
