[5th Gen : 08+]: A/C Condensate Drain, 2014 Caravan
Old Aug 22, 2022 | 12:57 AM
Ed60062's Avatar
Ed60062
Default A/C Condensate Drain, 2014 Caravan
When running the A/C on my 2014 Grand Caravan, I don't see more than a few drops of water on the ground. I'm thinking the drain line might be clogged but can't find where it is. The interior carpet is not wet but the water must be going somewhere. Does anyone have a solution to finding the drain line?
Old Aug 22, 2022 | 07:38 AM
The drain is under the van in the center, it is hidden by the heat shield. You need to remove the heat shield to access the drain.
