[4th Gen : 01-07]: 2005 Caravan SXT, not Grand, Radio and Clock out.
Old Oct 3, 2022 | 04:56 AM
dannykewl's Avatar
dannykewl
Default 2005 Caravan SXT, not Grand, Radio and Clock out.
2005 Dodge Caravan SXT, not Grand. Have the dead radio problem now, no sound, no clock or radio station frequency showing. I tried the RDO 20 amp fuse, as well as the 20 amp to the right, and the 20 amp IOD, even pulled the IOD fuse out for a minute and re-inserted as others have done, and tried pulling it out 3/4 as worked for others, nothing. I tried swapping another bigger 30 amp pink fuse, and also tried swapping the relay with the blower motor relay as instructed in YT videos, nothing. The periphery around the radio lights if I turn on headlights, in blue, such as on/off/volume, balance, AM/FM, CD eject, seek buttons, etc., but then so does the heater, etc., so I assume the blue is a backlight shining thru "cutouts" in the radio face, that's not part of the radio. 2 years ago had same problem, swapped one 20 amp fuse and it worked, this time, nothing. Cig. lighter below and all else works, and had an mp3 to FM transmitter plugged into the cig. lighter for a couple of years, but I assume that outlet doesn't affect the radio. IS THERE another place to look for fuses besides next to the battery? Thanks.
I get this with headlights on, but no clock/radio display or sound.
