[5th Gen : 08+]: Tire wear, driving issues.
Old Dec 16, 2022 | 03:21 PM
realfloopyguy's Avatar
realfloopyguy
Default Tire wear, driving issues.
2017 Dodge Grand Caravan SXT. 90k miles.
Something happened in the last 2 months with my wife's van. The drivers rear tire is completely worn and slightly more on the inside. When a bump is hit at interstate speeds, it feels like a shock is broken. It is noticeable at 50-60 but not before that. It drives straight down the road and feels fine aside from bumps. The rain makes it 10 times worse.
I drove it 1500 in October on the interstate and it drove perfect. The only thing I can think is my wife backed into a stump that is lower than the bumper but high enough to catch something. I was in the van, I think she got the tire directly. I didn't notice it after this though and I'm pretty sure I drove it after that.
My first thought was the shock was dead. I took it off and it feels as good as any new shock I've ever had in my hands. The van sits level, if I jump on the back or push in all 4 corners it pretty much levels immediately. The bearings sound and feel fine with no play or gravely sound. I've got a bit of experience and I can rebuild a front end and do crash repair, so I have a decent idea of what to look for.
Next, I thought maybe she clipped the trailing arm and bent it or messed up the bushings. I checked that. Made sure the mounts were aligned in the same place on either side. I checked the spring, it doesn't seem like the seat or anything is bad and it rides level so the spring being the problem seems unlikely.
I spent half an hour looking for impact marks. I don't see anything bent or hit. I took the tire and ran my hands over it looking for broken belts and other things. Aside from the wear, it looked OK.
I don't work on the rear end of front wheel drive cars much. I assume if I take it to a shop they are going to want to change the shocks but they felt like new. I didn't check the other side but I assume the bad tire would be the issue here if it were shocks.
Is there something I'm overlooking? Is it possible I just got a tire that sucked halfway into the wear pattern? I don't see anything that needs fixed. I could put a couple of the old tires that have 50% tread on them and take it to an alignment shop and see if it is an alignment problem. There is a 2014 in the junkyard, I could just go take the whole rear end out of it. It looks like it comes out in 1 piece for both sides.
Anyone have any suggestions on what to look for?
Old Jan 12, 2023 | 08:35 AM
realfloopyguy
Default Update
Replaced rear tire and shock on that side. Nothing different. Drives the same with traction control off.
I'm going to spend some time checking it again today.
Old Jan 12, 2023 | 03:44 PM
May just need an alignment.
Old Jan 12, 2023 | 03:58 PM
realfloopyguy
It doesn't appear to have anything that can be aligned.
It turned out the entire thing was bent. It just was perfectly center on the rear end and I guess I was looking at the side with a problem, so it wasn't obvious immediately. I picked up an entire rear clip for $80 at the junkyard today.
