00 caravan tranny
Old Jan 4, 2006 | 08:31 PM
dwaj76's Avatar
dwaj76
Default 00 caravan tranny
Its time to do a tranny flush in my caravan before i blow it. My Dodge dealer tells me the tranny fluid is called +4? I have read that if I use GM dextron3 or ford Mercon it will cause problems. Is the +4 a synthitic fluid? I work at a LInc/ Merc dealer and on top of the MErcon we also have a Mercon V that is a synthitic. Is that comperable. also my local carquest has a Mopar + 4 tranny fluid but i dont want to use that. Does anyone know if the Mercon V is compatible to the +4? Pleasse help!!
Old Jan 5, 2006 | 03:07 AM
acmectec2001's Avatar
acmectec2001
Default RE: 00 caravan tranny
Im not 100% sure but I dont think the Mercons are recommended for the +4 applications.
I know that Mercon and Mercon V arent compatible. I have a Ford Escape and there was a problem with the dipsticks being marked wrong and people were having tranny troubles with the Mercon V. They recommend only
Mercon for the Escape. The Mopar +4 should be fine. Mopar is Chrysler brand like GM/Ac Delco and Ford/Motorcraft.
Old Jan 5, 2006 | 09:45 AM
brandoncrone's Avatar
brandoncrone
Do not use anything but ATF +4. You will have numerous shift shudders, especially during torqu converter lockup
Old Jan 5, 2006 | 12:11 PM
dwaj76's Avatar
dwaj76
Thanks for the help i was afraid of that my local dealer wants way to much for the +4. Guess i will have to suck it up and buy it though. Thanks again
Old Jan 7, 2006 | 01:59 AM
DodgeRam318_4bbl's Avatar
DodgeRam318_4bbl
Try a local auto parts store like AutoZone or Advance Auto - They're always cheaper than the parts dept. I use ATF+4 in all of my DCX Vehicles. Anything else will tear up the transmission.
