[2nd Gen : 91-95]: how to get trans codes
Old Aug 1, 2023 | 11:11 PM
Damndodge1!'s Avatar
Damndodge1!
Unhappy how to get trans codes
the tester from the factory costs thousands of dollars. i just want to test my trans and do some diagnostics. help?
Old Aug 2, 2023 | 01:56 PM
You just want to get codes, a normal OBD 2 code scanner will work. What else do you want to do?
Old Aug 2, 2023 | 04:50 PM
Damndodge1!
it is a 95 and no hookups for obd2 otherwise i would have used that.
Old Aug 3, 2023 | 07:47 AM
In that case, do the key dance to get the codes if that's all you want. To start gathering trouble codes turn the ignition key on off in rapid succession five times ending the cycle with the key in the on position.
Old Aug 3, 2023 | 01:28 PM
Damndodge1!
Default trans codes
that's how you do it. everyone says to do the key dance but nobody explained it. thanks
