88 caravan
Old Nov 3, 2003 | 01:09 AM
c44eze's Avatar
c44eze
Default 88 caravan
My caravan starts and shuts off almost at once have checked fuel pressure at cranking speed changed computers replaced fuel regulator. Will stay running for a few seconds if pedal is pumped vigorously. What else should i check? It is a 4 cly. auto trans. help <IMG src=smileys/smiley19.gif border="0">
Old Nov 3, 2003 | 12:23 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Default 88 caravan
Maybe the Catalytic Convertor...Try turning the Van on and have a friend put their hand over the exhaust pipe, if nothing comes out (or very little air compared to the usual rush when a car is running) that's definately a problem.
~Amanda <edited><editID>Dodgegirl19</editID><editDate>37928.3918402778</editDate></edited>
Old Nov 4, 2003 | 05:58 PM
ViperGTS's Avatar
ViperGTS
Default 88 caravan
Im a bit confused on your sentences. But Probably the fuel pump is screwed up because my moms b/f had the same problem sorta. Can you explain it alittle further? </P>
thanks,</P>
matt</P>
Old Nov 4, 2003 | 06:05 PM
Dodgegirl19
Lady Administrator
Default 88 caravan
I had the exact same problem in one of my cars... it was the Calalytic Convertor then. I had to stay revving the engine to keep it running... and then I ended up dumping so much hot fuel into the Cat, it was glowing bright red... not good... LOL! I don't think it's the fuel pump... I'm sticking with the Cat...
Keep us informed of whatthe problem wasif you fix it C44EZE!!
~Amanda
Old Nov 4, 2003 | 08:29 PM
dodgefreak's Avatar
dodgefreak
Default 88 caravan
I am with Amanda on this one!!
Old Nov 7, 2003 | 04:00 PM
c44eze's Avatar
c44eze
Default 88 caravan
Tryed cranking checking exhaust seems to have good pressure. Does air intake need to be hooked up for thi car to run?
