[5th Gen : 08+]: Both RH & LH blinkers fast flashing
Old Oct 10, 2023 | 01:47 PM
HHBIII's Avatar
HHBIII
Default Both RH & LH blinkers fast flashing
I am at a loss. using the turn signal i get a fast flash but using hazards everything is normal. I replaced the bulbs with 3157s. same issue. replaced multi function switch same issue. checked all wiring grounds had 1.1 ohms from each socket to ground. swapped out TIPM still have same problem. does anyone have the wiring diagrams or other thoughts on what is causing this problem.
Old Oct 14, 2023 | 10:54 AM
HHBIII's Avatar
HHBIII
Default update
Back up lights not working now
