[4th Gen : 01-07]: PCM ground wire color codes and pin out diagram
Old Aug 10, 2024 | 01:08 PM
Dodgedcaravan2's Avatar
Dodgedcaravan2
Default PCM ground wire color codes and pin out diagram
I've got a 02 Dodge Caravan 3.3 se flex I'm in need of a wiring diagram for the pcm to find grounds for pcm. Does anybody have one they can possibly pdf file me at Hubcitypaint08@gmail.com. Thanks
Old Jan 21, 2025 | 09:03 AM
jbcompmanjr's Avatar
jbcompmanjr
Did you find the diagram anywhere?
I have a 2002 GC (not Flex) with a problem causing the PCM to continuously ground all injectors simultaneously. I'm hoping to find what wire coming into the PCM might be shorted causing this.
Old Mar 2, 2025 | 07:38 AM
jbcompmanjr
Try this site. Found what I needed there to fix mine. Well worth the small price.
https://portal-diagnostov.com/en/
Old Mar 3, 2025 | 03:10 PM
windowsontheworld's Avatar
windowsontheworld
Thanks for the reply. hose only go up to 2014 for the Grand Caravan. Any idea where I could get the diagrams for a 2019?
