[5th Gen : 08+]: 2016 Grand Caravan SXT Chime
Old Aug 21, 2025 | 09:31 PM
J'Kar's Avatar
J'Kar
Default 2016 Grand Caravan SXT Chime
Hello,
I just got van back after dealer had transmission rebuit and I noticed a new issue.
only had van less then 3 weeks.
I notice the chime does not work at all for anything.
No seatbelt sound, no key in ignition, no lights left on and anything else where chime should work.
So I was told to check fuse M13 which tested fine.
Is there anything else that could be causing the issue?
Could it have been disabled by someone with a good obd programmer/scanner or is last choice the instrument cluster?
And if it is the cluster could that mean someone swapped it out to change mileage in it?
Thanks
Old Aug 22, 2025 | 10:33 AM
J'Kar's Avatar
J'Kar
Hey Guys,
Never mind about my post as I got the answer.
Seems its a glitch with Uconnect and HFM need firmware update.
I just downloaded Firmware from Chrysler and will try tto update it on weekend as its going to take up to an hour.
Thanks.
Old May 19, 2026 | 12:12 PM
heramb.hatkar@gmail.com's Avatar
Hi,
Were you able to fix the issue? Did the chimes start working again.
Could you please share the steps you followed?
I have the same issue with my 2016 Caravan.
