[5th Gen : 08+]: AC Problems possibly door actuators
Hello so recently my Ac went out and i knew it was coming since i could hear that clicking noise from my door actuators on the passenger side to go out anyway i replaced all the actuators and now only my feet blow cold ac. i dont know what could still be the problem when i was replacing the driver side actuator when i went to grab at the connection port the wires came out more from where they orignally were i tugged on them so more but they didnt feel loose but this is where im at right now any ideas? i already ruled out fuses, the compressor and freon is filled.
I replaced the 3 three in front i didn't think there was 2 in the rear since my caravan only has ac in the front
We actually had the same problem. Has to buy the whole air box, as the arm broke on the blend door, which sucked after replacing all 5 in our van front and back heat and AC, the front blend door between hot and cold broke cost another 500 to have it properly fixed. Good lock coz they have to take out the whole dash to replace it.
We feel your pain. I didn't like the fast the actuators sweep every time you open a door even with not having the van on. I almost wanna put them in a switch at the fuse panel lol
Your recirc door could be broken, we sell blend door kits for dodge, if you want to explore that option you can email me your vin to ensure if our kits would work for your vehicle. chelsea@blenddoorusa.com.
Also we recommend using OEM actuators, aftermarket ones will eventually fail again and you will have to go thru the process all over again.
