cluster gauges not working
Old Mar 18, 2006 | 05:25 PM
Mike TD's Avatar
Mike TD
Default cluster gauges not working
I Have power going to the unit, I did replace the unit, also still no fuel speed or temp Readings[:@]
Old Mar 19, 2006 | 06:53 PM
ljshein's Avatar
ljshein
Default RE: cluster gauges not working
Mike,
I have the same issue with a 91 Grand Caravan SE. Reading the forums, they talk about bad solder on the master circuit board. I re-soldered the board and when I put it back together the gauges came on for a moment and then they were gone.
If the van sits for a while, the same thing occurs. It's almost like it's overloading a circuit.
Id love to know if anyone else has solved this issie.
Jeff
