Headlights
Old Apr 6, 2006 | 02:14 AM
acmectec2001's Avatar
acmectec2001
Default Headlights
I bought a used 98 T&C a while back. I dont drive it often, the wife does. We went out tonight and it was raining and I noticed how bad the headlights suck. This is the first van Ive ever had. I drive home from work in the dark and the headlights on my other 2 cars seem to be a lot brighter than the ones on the van. They are aimed fine , they just dont seem bright enough. Do the bulbs get dimmer over time? They are both working.They look like the kind that reflect off of the back of the headlight assembly. Is that just the way this type of headlight is or is there something that can be done to make them better?
Old Apr 9, 2006 | 02:13 AM
mikest34's Avatar
mikest34
Default RE: Headlights
Somtimes after awhile the outer headlight assembily gets daul. or it draws dampness maybe thhat is your problem
Old Apr 19, 2006 | 05:48 AM
minivanin's Avatar
minivanin
bulbs do get dimmer as they age
get some eurolites or some piaas or hellas, all good bulbs
-greg
Old May 9, 2006 | 03:49 AM
ve7dvb's Avatar
ve7dvb
Did you turn them on or are the Daytime Running Lights on instead?DTR will give 1/2 the output of your high beams which is a lot less than low beam.
Old May 9, 2006 | 12:37 PM
Kolhoznik's Avatar
Kolhoznik
Sylvania silverstars did the job fine for me...
Old May 31, 2006 | 11:41 PM
epic_soundz69's Avatar
epic_soundz69
I have a '95 caravan and the headlight covers get dirty and dim the lights a lot.
I used this stuff called "Flitz" and it worked perfectly for about 5 months then they started getting dirty again, so I re-polished them and they're like new again.
I found the flitz at home depot.
Old Jun 15, 2006 | 05:20 AM
minivanin's Avatar
minivanin
i'd spray a thin sheen of clear coat after that, it'll seal it, i used polishing compound on mine then cleared it, they haven't dulled since, about 1 1/2 years ago
just that they are little dull inside....i'll mount my projectors soon...
-greg
