What do I need to change a wheel stud?
Old Apr 24, 2006 | 01:58 PM
mike_wiz's Avatar
mike_wiz
Default What do I need to change a wheel stud?
A wheel stud broke off the front tire the other day. 2000 Grand Caravan. What will I need need to pull it out and put in a new one?
Old Apr 25, 2006 | 12:31 PM
wraithyvan's Avatar
wraithyvan
Default RE: What do I need to change a wheel stud?
take tire off,,, to do that you will need to jack up van and safely support it, take brake rotor off (not sure of the type of rotor the van uses as I have not had it off yet) either pound the stud off the rotor or off the spindal.
align broken wheel stud with a space behind the spindal so it can clear when you it it with a big mutherfcknhammer BMF
pound out the stud.
place new stud in the hole as best you can and as far as you can couple taps with hammer on a scocket on the new stud.
then put on a bunch of washers and the wheel nut and tighten it up pulling the stud into it's seated position or close to it.
put tire on and bolt up lug nuts to proper torque.
you'll notice that it may take extra turn to get the new stud torqued to spec this is cause it is fitting into it's seated position.
good luck
Old Apr 25, 2006 | 03:03 PM
mike_wiz's Avatar
mike_wiz
Thanks for the reply, I'm going in the shop right now to get it done. I was hoping I did not have to remove the whole hub.
Old Apr 25, 2006 | 06:15 PM
webbee's Avatar
webbee
It's best to take the hub off and press the stud off/in. You can ruin the bearings if you knock too hard on the stud.
