'94 3.0 v6. accident, no error codes at all
Old May 27, 2006 | 09:52 PM
iodizedsalt's Avatar
iodizedsalt
Default '94 3.0 v6. accident, no error codes at all
i was in an accident and the driverside front end got bashed and when i attempt to do the on-off-on-off-on to check the error codes, nothing happens. no check engine flashing, not even the 12 55.
it turns over and sparks (i sprayed some jump spray into the intake and it putts a few times, but it's not getting fuel) and the ecu board has a chip in it from where the frame hit it and one of the deals with the heatsink got jarred. i've checked the auto-shutoff and it's working properly.
i've heard there is also an impact-sensitive valve in the fuel pump assy. also. what am i looking at here? i'm guessing the ecu will need to be replaced but is there other places i should give my attention to?
thanks
Old Jun 1, 2006 | 09:18 PM
iodizedsalt
Default RE: '94 3.0 v6. accident, no error codes at all
so, i went to a junkyard and got an ecu from a 1995 plymouth voyager for $75 and installed it and my vehicle started right up. (napa wanted $350 for one of them badboys, btw)
hoo-rah.
Old Jun 2, 2006 | 12:27 AM
greaseangel's Avatar
greaseangel
Congrats! Isn't it great when things actually work right?
