Changed starter... no A/C!
Old Jun 7, 2006 | 01:10 AM
danl's Avatar
danl
Default Changed starter... no A/C!
Hey everyone,
I was replacing my friends starter on her 1995 Dodge Grand Caravan 3.3 L (has rear A/C), and after the van was returned, my friend told me that the A/C was no longer blowing cold air. I checked the fuse and it was fine, and I even took both battery cables off for 15 minutes, hoping to reset the computer if anything had happened there. Still nothing though. The A/C clutch does work, ive checked to make sure it engages. I just can't figure out why it would stop working over night. I am for certain that I did not mess with any of the A/C stuff while working on it, so I don't think that I did anything. If anyone has any ideas, let me know! Thank you!
Danny
Old Jun 15, 2006 | 05:07 AM
minivanin's Avatar
minivanin
Default RE: Changed starter... no A/C!
double check the connections, they tie into the same harness as the starter is, most likely you disconnected it & forgot, or knocked it loose, jack 'er up, crawl under & take a peek at that wiring, i bet thats what it is
-greg
