On board diagnostics
Old Jun 20, 2006 | 04:00 AM
Juanita's Avatar
Juanita
Default On board diagnostics
Hi...I did the code thing and was wondering if anyone can tell me what error code 12 means.
Thank you!!
Old Jun 20, 2006 | 01:14 PM
greaseangel's Avatar
greaseangel
Default RE: On board diagnostics
Code 12 is "Direct battery input to PCM was disconnected within the last 50 Key-on cycles."
Old Sep 10, 2006 | 08:46 PM
MTRam's Avatar
MTRam
I get the MIL or CEL (Whichever you want to call it) only after the engine turns on. When I did the ignition trick to get the code, all I get is 55's, which according to allpar.com is saying the codes are done. Any thoughts?
Old Sep 10, 2006 | 10:40 PM
dodgerules86's Avatar
dodgerules86
MTRam, do you mean, as soon as you turn the key forward? Try this: turn the key to ON (not start) and leave it there. If the light goes on after a few seconds, this is normal. It's called the bulb check.
Old Sep 11, 2006 | 02:50 PM
MTRam's Avatar
MTRam
DodgeRules86,
I appreciate you getting back to me so soon.
Sorry should have been more explanatory. When I turn the key to on, it performs the bulb check normally, then goes out. When I start the engine, it comes on and stays on. It is a 99 Grand Caravan, aprox 131k, I think the 3.8l, would have to double check on that.
In essence, the MIL doesn't come on until after the engine is running. Any ideas?
Old Sep 12, 2006 | 07:49 AM
dodgerules86
ORIGINAL: MTRam
DodgeRules86,
I see. I would take it to an auto parts store and have them hook up their code reader while you start the vehicle up and see if they get anything.
I would also recommend browsing the TSB's .
You could probably go to a stealership and talking to an actual mechanic there, and see if you can pry some free information out of them. Let us know what you find.
Old Sep 12, 2006 | 12:07 PM
MTRam's Avatar
MTRam
Exactly! What I mean is, yesterday, before I read your last reply, I went to Checker Auto Parts. They will run the scanner and print out the checks on paper for you for free. Turns out, it was the old gas cap trick. He shut the code off, and it has not come back on since. Thank you DodgeRules and Checker.
