New Member with 93 Grand Caravan
Old Jul 25, 2006 | 05:50 PM
Grandcaravan's Avatar
Grandcaravan
Default New Member with 93 Grand Caravan
Hello, I have a 93 Grand Caravan, 3.3, 273,000 miles, and I am having a weird brake problem. When you put your foot on the pedal it has some much pressure against it it wont move. Not like a bad booster ( which I checked for) where you can force it down, I mean you can't move it at all. Had it took to Dodge dealer, said 1800 bucks for ABS system repairs, can I disable the ABS and drive with regular brakes? I have heard of this, but I am not aware of the correct proceedures.
Thanks, Dave
Old Jul 26, 2006 | 01:45 PM
chopper's Avatar
chopper
Default RE: New Member with 93 Grand Caravan
Try removing the fuse for the ABS.You can drive with the ABS disabled.
Old Jul 26, 2006 | 02:36 PM
Grandcaravan
So, just removing the standard fuse in the box under the dash will cut off ABS, and all of its quirks ?
Thanks, Dave
Old Jul 27, 2006 | 12:44 AM
minivanin's Avatar
minivanin
i remove the fuse on mine, for some reason when you hit the brakes like to come to a nice stop, not slamming on them, the abs will kick on & i would lose most of my braking power, i almost rear ended a few people, so i pulled the fuse, before i'm even out of my neighborhood it relaizes it, kicks the ABS light on, & i'm on my marry way, plus i prefer normal brakes anyways
-greg
