Power Outlet max power draw
Old Jul 29, 2006 | 03:06 PM
lohesn's Avatar
lohesn
Default Power Outlet max power draw
Anyone know how many amps can be drawn from the power outlets on a '99 Caravan before blowing fuses? I cannot find in the owners manual even which circuit it is on, so I'm not sure of the fuse rating.
Thanks.
Old Jul 31, 2006 | 11:14 AM
ASH's Avatar
ASH
Default RE: Power Outlet max power draw
Pull off the cover of your fuse panel. It is on the side of the dash, driver's side. The fuses should be labeled on the inside of the cover. The label should give the description of the fuse and the amperage. My guess is that the fuse should be 20 amp.
