A/C drip in passanger frong
Old Jul 30, 2006 | 07:54 PM
lonkelm's Avatar
lonkelm
Default A/C drip in passanger frong
I have some water dripping from my a/c into the passanger front. It lands on my wifes foot. Any TSBs out there to take care of this? Any others having the same problem?
Old Jul 31, 2006 | 11:04 AM
ASH's Avatar
ASH
Default RE: A/C drip in passanger frong
Check to see if your drain line from the evaporator is plugged up. Sorry, I don't have any pictures to show where it is located. Also, make sure it is water and not anti-freeze. If if is anti-freeze, your heater core of the lines connecting to it could be leaking.
Old Dec 17, 2006 | 03:38 AM
PeterNY's Avatar
PeterNY
Does the drip happen after arain storm? Does it slosh in when you drive around a corner? - your firewall drain hose may be plugged. It's located under the hood on the passengers side. Pull the black hose off and it will drain. Blow it out to clear it.
