2001 GCS Front Windshield Washer - NO output!!
Old Aug 13, 2006 | 09:29 PM
Byounghusband's Avatar
Byounghusband
Default 2001 GCS Front Windshield Washer - NO output!!
I have a 2001 GC Sport and the Front windshield wsher has no output.
I have:
1. Filled the reservoir.
2. Swapped relays between the front and rear washers and no change.
3. Replaced the FT/RR Washer 15a fuse.
What else? Where is the motor mounted? I tried to trace the lines from the sprayers, but can't even get ot them.....
TIA!!
Old Aug 14, 2006 | 12:10 PM
chopper's Avatar
chopper
Default RE: 2001 GCS Front Windshield Washer - NO output!!
Can you hear the spray motor running?If so the spray heads must be clogged.The blockage is usually in the head and can be opened with a needle or fine wire.
Old Aug 15, 2006 | 02:07 AM
veaumjj's Avatar
veaumjj
The motor is located in the front fenderwell immediately in front of the passenger side front tire. I cant remember the exact procedure for getting to it but the front and back washers have thier own separate motor inserts that insert, if I remember right in the bottom of the fluid resevior. I accessed it from underneath. I think the part was about $18 at the dodge dealer and it took about 20 minutes to replace.
Old Aug 15, 2006 | 12:37 PM
Byounghusband
Chopper,
No I didn't hear the motor, but will check again, now that I know where it is located.
Veaumjj,
Thanks for the tip on the motor location. Sounds like a fairly easy fix!!
Later,
Old Sep 3, 2006 | 01:21 AM
rabtrfld's Avatar
rabtrfld
I once found red ants blocking the windshield washer tubing. They must like methanol.
