electrical connectors pinout/diagram
Old Aug 21, 2006 | 11:42 AM
dalek's Avatar
dalek
Default electrical connectors pinout/diagram
Does anyone have the electrical diagrams for a 89 and a 92 Caravan? I want to do put the entire engine harness from the 89 on the 92 and found my Haynes to be rather useless. Specifically the pinouts for the bulkhead connectors for both minivans would be quite appreciated.
Old Aug 28, 2006 | 02:21 PM
nmlhaus's Avatar
nmlhaus
Default RE: electrical connectors pinout/diagram
Hi. I purchased the factory manual for my 94gc, and friend, you have no idea how much information is in it. There has to be over 100 pages in the wiring diagram section alone. The diagrams are laid out somewhat confusing, and it took me several hours to get the hang of following them at all (I'm an E.T. and used to dealing with complex wiring, and it still was tough!). I would really recommend that you invest in a manual if you can, perhaps start with the newer model and then compare it to the older.....There's usually a lot of similarity.
GOOD LUCK
