Help DAM LIMP MODE
Old Aug 29, 2006 | 09:59 PM
thowell's Avatar
thowell
Default Help DAM LIMP MODE
The lastest....
When I get up in the AM and leave for work the van works perfect.........But
When I leave after work the van will not come out of LIMP mode no matter what I do
When I start the van at work the tranny will not go into drive for a sec than it goes into LIMP MODE and no matter how many
times I restart it the dam thing stays in LIMP, but Like i said in the morning it work perfect....no LIMP at all
WEIRD
any Ideas out there
P.S. does anyone know the wire numbering for the TCM ans ECM control plugs so I can test them
Thanks
bump
Old Sep 4, 2006 | 02:38 AM
99GrCaravanSE's Avatar
99GrCaravanSE
Default RE: Help DAM LIP MODE
Go to get the OBDII Code reader at AutoZone (Get the loaner unit if you put down the deposit). Once you reader the code and it will tell you which sensor it is. I repaced the speed output sensor and it was less than $25. If I have taken it to the dealer, it would have cost me $400-$500.
Good Luck,
Tony
