95 Caravan SE top speed
Old Aug 30, 2006 | 02:42 AM
epic_soundz69's Avatar
epic_soundz69
Default 95 Caravan SE top speed
I drive a 1995 Caravan SE 3.0 and I was just wondering what the top speed is on other peoples vans.
Old Aug 30, 2006 | 02:55 AM
minivanin's Avatar
minivanin
Default RE: 95 Caravan SE top speed
well before i ported the heads on my 3.3, my 198K mile (at the time) with bald tires, bad axles, bad inner tie rod ends, completly worn suspension pulled 120mph out of its ***
BTW it was confirmed by my friends turbo jetta who couldn't believe it either, lol
that was in third gear BTW, i backed out after that, it was shaking too much, but who knows how much further it could go while in overdrive ( i doubt much more)
-greg
Old Aug 30, 2006 | 02:58 AM
epic_soundz69
You seem like you know a lot about the caravan, so I gotta ask you, what are some things i could do to get more power out of my van. Things that are hopefully not too expensive.
Old Aug 30, 2006 | 04:16 AM
minivanin's Avatar
minivanin
ok
first of all, make sure yours is in tip top shape, do a tune up, cap, rotor, wires (MSD prefferably), & NGK V-power or G-power plugs, don't get champions, people will swear by them, but i don't trust plugs that have failed several times in my experience, including one falling apart in a cylinder, NGK has never let me down, & i wouldn't waste money like i did on Bosch plugs, while your there doing the tune up, run a compression test to see if anything is going on in there
well most likely you have the 48mm TB (throttle body), go to a junkyard & find a caravan, or any other vehicle equipped with a 3.3/3.8 engine, grab the trottle body, its 52mm, everyone with a 3.0 does it, & it works, i always hear claims of more power & improved gas mileage, BTW clean it with some carb cleaner before you put it on, you'll get a nice little throttle tip in whistle, plus it helps a tiny bit too
now you should be able to swap it right on there, the sensors can be swapped it if makes you feel better, but is not neccesary
next thing would be an intake, what seems to work is get a K&N cone filter (or a ricer filter of your choice) & just simply clamp it on the end of the rubber tube that connects to the air box, its cheap, easy & cost effective
next would be to open up the exhaust, a good mandrel bent 2.25inch exhaust should be enough, if the shop can't offer mandrel bends, knock it up to 2.5 inch, go with a known muffler, a Flowmaster will outperform all, but a Magnaflow, or a Dynomax ultraflo muffler, will be enough, plus get a high flow cat too
after that, i would consider having the tranny rebuilt using Kevlar clutches, & all the updated parts for it, plus a shift kit, pin savers, & possibly a higher stall torque converter would really make a difference, if the shop laughs at your face, go to another one
after that, we'll, lets worry about the above stuff first
-greg
Old Aug 30, 2006 | 10:09 PM
epic_soundz69
Thank You Dude! Youre the only one who has given me an answer clear enough to follow.
Its funny seeing the faces of the people with their "upgrades" when you floor them in a minivan.
They especially trip out when i tell them that all i have is a K&N drop-in replacement filter. He he, suckers.
Old Aug 31, 2006 | 07:06 PM
minivanin's Avatar
minivanin
i love seeing those faces!!!
have fun, & if you got any questions, just send me a message, & you might wanna check out Allpar.com, we have a nice minivan section over there, & i'm a regular member over there
-greg
Old Aug 31, 2006 | 10:10 PM
epic_soundz69
and a site too, awesome
