2001 Caravan starting problem
Old Sep 18, 2006 | 06:16 PM
manyhats's Avatar
manyhats
Default 2001 Caravan starting problem
2001 Grand Caravan with sporatic non-starting problem. For the last 4 months, I have had a problem with van starter motor going, but engine not turning over. Sometime I smell gas. After a few tries, it will usually start right up and then not have the problem again for many days. The weather is not a factor, nor is the temp. of the van. Have a new battery and new ignition coil. Dealer has checked all ignition parts and fuel system---no problem found. CAn anyone help?[:@]
Old Sep 18, 2006 | 06:52 PM
cryrose's Avatar
cryrose
Default RE: 2001 Caravan starting problem
e-85 feul? If you are running it will cause a delay in the start of the caravan.
Just an idea. I don't care how cheap it is I will never run it again in mine - to much trouble with starting, only run one tank, that was enought for me.
Old Sep 19, 2006 | 12:11 PM
manyhats's Avatar
manyhats
NO, E-85 has never used in the van. Thanks.
