96 caravan interior blower only works on high
Old Jul 14, 2004 | 06:32 PM
tjs's Avatar
tjs
Default 96 caravan interior blower only works on high
The interior blower in my 96 grand caravan only works when the blower speed control switch is rotated to the highest setting.
Does this sound like a problem with the switch itself or is there another place I need to look first? (The 40A blower fuse in the power distribution center is okay.)
Thanks!
tjs
Old Jul 14, 2004 | 08:00 PM
lvd2340's Avatar
lvd2340
Default RE: 96 caravan interior blower only works on high
Sounds like a blower motor resistor. Part # is 4677180AD and should run about $15 and is located at the back of the engine compartment on the passenger side of the vehicle under the wiper module.
Old Jul 15, 2004 | 03:52 PM
tjs's Avatar
tjs
Thanks for the recommendation--I'll go ahead and replace the resistor, and let you know how it turns out.
tjs
Old Jul 15, 2004 | 10:35 PM
tjs's Avatar
tjs
The resistor was indeed the problem--one wire had completely corroded off the breadboard. I replaced the resistor and the blower works like a champ. Interestingly, the dealer knew the exact part number by heart. Must be a common problem.
Thank you very much for the advice.
tjs
