Spark plug replacement on 2000 Grand Caravan
Old Jun 22, 2006 | 01:43 AM
Blkblurr's Avatar
Blkblurr
Default RE: Spark plug replacement on 2000 Grand Caravan
I am replacing the clutch on the A/C on a 2000 Caravan and have not worked on a caravan before. How do you remove the tension on the serpentine belt?
Old May 15, 2011 | 08:57 PM
HuffmanFamilyof4's Avatar
HuffmanFamilyof4
I found the best way to change the rear 3 spark plugs is to remove the windshield cowl just at the bottom of the windshield, you will need to remove the wipers. it is the easiest way I found to change those plugs. you can try it the other way first then try my way, I think you will be quite surprised on how much faster it goes.. good luck.
P.S. look for the reference marks on the windshield for lining up the wipers they are small lines near the bottom of the glass
