abs light
Old Jul 20, 2004 | 04:29 PM
navarac's Avatar
navarac
Default abs light
hello everyone
I just joined the forum
I have '02 grand caravan sport @42000 miles on it.
abs light came on the other day, noticed that the pads were low so I replaced both pads and rotor. But abs light is not going away. Is there reset switch or some other reset method for the abs light? Before I take it over to the dealership to hand over my wallet.
any response would be appreciated!
Old Jul 24, 2004 | 03:37 PM
JCswm's Avatar
JCswm
Default RE: abs light
LOTS of problems with the rear wheel sensors
replace them both!!!
ALSO there have been a few that the wireing harness in front of the transmission is pulled TIGHT on the solinoid pack & rubbing through the harness.... The RR wheel speed sensor wire is the first to get grounded. move that harness & look for an exposed wire!!!
Let me know if that helps,
John
Old Jul 28, 2004 | 03:05 PM
navarac's Avatar
navarac
thanks for your advice JCswm
I'll try it this weekend.
I've also found out that, you need scanner to clear the code.
Disconnecting the battery doesn't do it anymore.
Does anybody know of cheap scanner or other method to erase the code.
