Driver Side window regulator/motor replacement
Old Jul 25, 2004 | 02:19 PM
pk's Avatar
pk
Default Driver Side window regulator/motor replacement
I am planning to replace the Dodge caravan 97 driver side window regulator and motor. I need help in replacing the
window regulator and motor specially the trim and weather lining to replace the regulator for automatic window ( Driver side).
Old Jul 27, 2004 | 08:48 AM
monsta's Avatar
monsta
Default RE: Driver Side window regulator/motor replacement
I watch this thread with great interest as I have to do the same... I now have an old, folded up tablet holding up my window!
Where'd you get the new regulator from?
Old Jun 19, 2006 | 11:36 AM
sunflower's Avatar
sunflower
how do you remove the inside door panels on the dodge caravan ?
Old Jun 19, 2006 | 05:59 PM
DodgeRam318_4bbl's Avatar
DodgeRam318_4bbl
Unscrew the screws around the switches and inside the armrest pull handle, disconnect the electrial connectors, and then !CAREFULLY! pry the panel off.
