97 caravan sport 3.3L shift problem
Old Dec 11, 2006 | 09:23 PM
gedi21592's Avatar
gedi21592
Default 97 caravan sport 3.3L shift problem
Seems to only happen on cold morning starts. Van starts fine put into R no prob. Get out of driveway will not shift into D or any other gear for that matter. If put back into P and rev motor for few minutes will eventually go into gear. After that no prob for rest of day. Any suggestions?
Old Dec 12, 2006 | 12:33 AM
brandoncrone's Avatar
brandoncrone
Default RE: 97 caravan sport 3.3L shift problem
Low on transmission fluid.
Old Dec 13, 2006 | 05:34 AM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
Is it only like that on cold mornings? If you check it and it has enough transmission fluid, then the issue is that the transmission fluid needs to warm-up to where it isn't so thick.
