found you by accident
Old Dec 15, 2006 | 04:54 PM
rovingroger's Avatar
rovingroger
Default found you by accident
I went looking for info about my 96 caravan and came across the site. I have two questions i'm looking for answers to. #1 is what could be causing my transmission to slip 4 times from startup and then lock into second (3.8/4auto), and if it is the trans will a 4speed from a 92 van w/3.8/4auto work in the 96?
Old Dec 16, 2006 | 01:05 AM
brandoncrone's Avatar
brandoncrone
Default RE: found you by accident
Could be a number of things. The only way to find out is to take it somewhere and see what codes are stored in the transmission controller. No the trans from a 92 won't work, the 96 has a motor mount on the rear of the transmission where the 92 doesn't and there are no provisions for the mount either.
Old Dec 16, 2006 | 03:08 AM
minivanin's Avatar
minivanin
plus the electronics are different, different signals
also, have you checked your fluid?? whens was the last time it had a filter & fuid change, & be sure to run ONLY +4 in it, not +3 or something else with an additave
-greg
