Oil Light flashes
Old Jan 20, 2007 | 10:47 PM
j1300's Avatar
j1300
Default Oil Light flashes
Ok so my oil light in my 98 grand Voyager flashes when we stop at a light we had the oil changed and that didnt help any idea's?
Old Jan 20, 2007 | 11:46 PM
mazdab2600's Avatar
mazdab2600
Default RE: Oil Light flashes
have the oil pressure checked at a trusted garage
could be a faulty pressure sensor for the light
but could also be low oil pressure caused by worn bearings or oil pump itself
Old Feb 23, 2007 | 02:40 PM
kabhatti's Avatar
kabhatti
I have the same symptoms, took it to the garage, though he didn't have time to check the oil pressure, he still recommended changing the oil sensor/sending unit and use heavier oil. I just changed the oil sensor/sending unit last night, so far the light only came on for a split second. The 3.3L engine has 135K miles.
Old Feb 24, 2007 | 05:55 PM
kabhatti's Avatar
kabhatti
Good news! Just to update and confirm that the oil sending unit was the culprit for the engine light turning on at stoplights and idle. I drove it all day, city and highway, its cured.
