1998 Caravan Rear Defroster
Old Jan 28, 2007 | 07:09 PM
adrummond3's Avatar
adrummond3
Default 1998 Caravan Rear Defroster
The rear defroster doesn't work. The dash light is on. I checked all the fuses (near the parking brake) and
near the battery. The window strips seem fine and undamaged. What to try next?
Old Feb 11, 2007 | 03:41 AM
Buster52's Avatar
Buster52
Default RE: 1998 Caravan Rear Defroster
I have the same thing wrong with my 98 Caravan. Let me know if you find out how to fix it.
Old Feb 11, 2007 | 04:17 AM
mazdab2600's Avatar
mazdab2600
if the relay clicks use a volt meter to check the contacts on the window
there a soldered lug on each side + and -
mine was just corrosion from themoisture on these
unpluggedsanded the lug plugged back in
might be an easy fix
