Bumper cover
Old Jan 31, 2007 | 12:26 AM
tuppercouple's Avatar
tuppercouple
Default Bumper cover
How do I install a new front bumper cover on a 200 Dodge Caravan? is it easy?
Old Jan 31, 2007 | 12:41 AM
mazdab2600's Avatar
mazdab2600
Default RE: Bumper cover
right from haynes manual
not working pm'd
Old Jan 31, 2007 | 12:55 AM
tuppercouple
Thanks.
Old Jan 31, 2007 | 01:13 AM
floorslayer1's Avatar
floorslayer1
It is very easy. Haynes description and pictures suck (I just went through this 3 weeks ago) There are 2 8mm bolts on each side(4 total)connecting the bumper cover to the fender and can be accessed by pulling inner fender shroud away and using an extension. Then there are a couple of 10mm bolts up above the grill area. Plan on buying a package of new push pins for underneath along the valence that hold the bumper cover up all the way across from underneath. The grille does not need to be separated and can be left as an integral part of the bumper cover. There are also several philips head screws as I recall along the fender well (2 or 3 each side). Good luck and take your time.
