TRANSMISSION
Old Feb 20, 2007 | 01:55 PM
ALLDODGE's Avatar
ALLDODGE
Default TRANSMISSION
1998 CARAVAN 3.3L OD PUT TRANSMISSION IN DRIVE SPINNING IN SNOW THEN PUT IN REVERSE THEN NO MOVEMENT AFTER IN PARK THE TRANSMISSION WILL ENGAGE INTO GEAR,IS IT GOING BAD OR IS THERE A SAFTY TO PREVENT OVER HEATING,ALSO THE SALVAGE YARD TELLS ME THAT ONLY A TRANSMISSION OUT OF A 98 WILL WORK,WHAT ABOUT 1996 TO 2000.THANKS FOR THE HELP
Old Feb 20, 2007 | 04:47 PM
floorslayer1's Avatar
floorslayer1
Default RE: TRANSMISSION
One of the largest reasons for failures of the A604 is spinning the tires at high RPM's. Often the differential will fail. Been there - Done that! - Many times lol...
The only differences are a couple of sensor connector styles. Easy enough to transfer from your old tranny to new one anything that doesn't connect right... Only one I wouldn't necessarily recommend swapping over is the solenoid pack. Just make sure the one you get from the junk yard wasn't smoked. Check the flexibility of the output shaft seals and that will tell you alot about the mileage and sometimes how hot it may have gotten. Another junkyard trick is to dump fresh fluid into the torque converter or into the pan to make it look good. Take a 10mm socket and remove the tranny pan and look at the magnet and tarnish in the pan. If they won't let you do that look for a place that will.... Been there and done that also, the hard way..... Good Luck
