97 Caravan fires once then no more
Old Feb 24, 2007 | 08:37 PM
OneLessHat's Avatar
OneLessHat
Default 97 Caravan fires once then no more
Hello all,
I am new here, and under unfortunate circumstance. I am working on a 1997 Grand Caravan. I will keep this to the short version of the story. It will fire to plugs and injectors one time, then nothing more. If I turn the key off and try again I getthe same thing. Every once in a while noid light on injector will light up to twice. It has new crank sensor.
I appreciate any leads, help, advice
Old Mar 18, 2007 | 09:33 PM
cuda325i's Avatar
cuda325i
Default RE: 97 Caravan fires once then no more
i had this on a 96..it was the pcm..but check the wiring from the coil to the pcm first for an open
