06 GC Vibration
Old Feb 25, 2007 | 11:06 PM
ztac39's Avatar
ztac39
Default 06 GC Vibration
I have a vibration at slow speeds 5-25 mph seems to go away from there. It has 20k and I do see a dimple on the sidewall ofa couple of thetires that runsup tothe tread. I am wondering if that could be the cause. The harder you accelerate and into turns at that speed you can feel it. Thanks for any input.
Old Mar 1, 2007 | 12:29 AM
89turbomini's Avatar
89turbomini
Default RE: 06 GC Vibration
is your air presser set at 35 or close check for worn tire on the front too. hit a pot hole bent rim? alan
Old Mar 1, 2007 | 01:57 AM
mazdab2600's Avatar
mazdab2600
some of the info here might help you with your tire's
http://www.toyo.com.au/TechInfoPDFs/...nd%20Bulge.pdf
