transmission problems
Old Mar 4, 2007 | 05:58 PM
corsario's Avatar
corsario
Default transmission problems
My caravan gave me a neutral switch error code so I got it at mopar and try to replace it. The problem began when I removed the valve body, I did it carefully so I dont remove the bolts that keeps it assembled,I pulled the valve body down and it came to me , but two pistons and tow springs fell dowm the trany and Idont kow how to put them back.Do they go first the spring and then the piston facing down or first the piston facing up and then the spring or a combination . I looked at the valve body and found a mark on it that told me that the first piston was facing up first then the springbut Im not sure about the second one, Can some one help me ?
thanks,
corsario
