Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
2009 Challenger burned out wire
Old Jun 1, 2016 | 11:25 PM
testerXXX's Avatar
testerXXX
Default 2009 Challenger burned out wire
Pulled into my driveway and tuned off my car. I decided to put it in the car. I started to turn the car on using the key fob because the keyless start doesn't work. Smoke came rolling from under the hood and the car never started up. I popped the hood and found the faulty wire. The faulty wire is pink/black. From google searches I believe the wire in question is the instrument gauge ground wire. It is attached to a ground screw. The wire did melt the plastic cover in several places. It is the only wire that burned up. After finding the wire I tried starting the car again and it did start and all gauges work. I'm asking for any ideas why this would have happened? The only known electrical problem is a loose screw on the alternator positive wire. Could that have been the reason the wire burned up? Have I correctly identified the wire?
