Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Knocking in gearbox
Old Sep 19, 2017 | 10:05 AM
dcoakle's Avatar
dcoakle
Default Knocking in gearbox
2013 Dodge Challenger SXT.
there is a knocking in my gearbox when I put car in drive or reverse and park. Also, The e brake light, abs, stability control, and traction lights are lighting up. Cant figure out what the problem is.
Old Sep 19, 2017 | 10:26 AM
You will need to get the codes scanned for the lights, not an OBD scanner either, will need to go to a shop to gwet those codes read and that will tell you the issue. . Don't know about the gearbox, I assume you are a manual transmission since you refer to it as a gear box. Could be a transmission mount, synchros, gears themselves, low on oil, etc. Don't say how many miles, so maybe it's due for scheduled maintenance.
Old Sep 19, 2017 | 11:21 AM
dcoakle's Avatar
dcoakle
Thank you, it is a automatic transmission, it's knocking when I put it in park, reverse, and drive. It occasionally knocks while driving as well. Those lights only illuminate when the knocking occurs.
Old Sep 19, 2017 | 11:58 AM
I would inspect the obvious things first, as I mentioned, transmission and engine mounts for starters.
Old Sep 19, 2017 | 12:29 PM
dcoakle's Avatar
dcoakle
Thank you, about how much is the repair cost on that?
Old Sep 19, 2017 | 12:40 PM
That I cannot tell you. Labor costs vary by location. Call around some shops and maybe have an inspection done first to determine if that is the actual cause of the issue.
Old Sep 19, 2017 | 01:54 PM
DodgeCares's Avatar
DodgeCares
Hi dcoakle,
Sorry to hear about this! If you decide to visit your local dealership for further diagnosis I'd be happy to offer assistance if needed. Just send us a PM with your VIN and let me know.
Andrea
Dodge Social Care Specialist
