Sponsored by:
Sponsored by: CARiD
installing aftermarket headlight bulbs
Old Apr 6, 2007 | 12:31 PM
ondaslab's Avatar
ondaslab
Default installing aftermarket headlight bulbs
i tried to reach in and replace the factory headlight bulbs but could not get my hand in there. Has anyone installed aftermarket bulbs like piaa or silverstars in there charger ?
thanks
Old Apr 8, 2007 | 11:57 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: installing aftermarket headlight bulbs
Welcome ondaslab.
Several on the forum have changed out thir HIDs, hopefully they will chime in once the holiday weekend is over. Personally I haven't done this yet. From what I've read in the pastit's plug-n-play.
Old Apr 19, 2007 | 03:07 PM
Midnight Blue's Avatar
Midnight Blue
The low beams are a tight fit so if you have large hands it might be problem. Other than that it's twist the bulb to unlock and remove.
Redbeard
Old Apr 21, 2007 | 01:22 PM
bradbates1998's Avatar
bradbates1998
i have a rt and i put some in mine and to get them in the drivers side you have to remove the air box and the pass side should go right in but be careful getting them out i twisted mine wrong and took me a hour to get the bulb to where it would come out
Old Apr 22, 2007 | 12:38 AM
Midnight Blue
I have the K&N on mine so I was (barely) able to slide my hand in without removing the air filter. The original factory bulbs were pretty snug so do some fingertip pushups to get ready . CCW to remove, CW to install.
Redbeard
