Sponsored by:
Sponsored by: CARiD
difficulty turning the beast over
Old May 15, 2007 | 03:35 PM
Hendge's Avatar
Hendge
Default difficulty turning the beast over
twice last week my R/Tdidnt start up after turning the key. It did turn over the next try. Sounds like it's trying, usually just starts right up immediately. I hear it trying for like3 seconds.
I know the easy answer is take it to the dealer before it leaves me stranded somewhere. I have just over 5k miles. I think it's eitherbattery, starter, alternatorproblem....but, i'm not sure.
Just curious if anyone here has any thoughts?
thanks
Old May 15, 2007 | 04:29 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: difficulty turning the beast over
It could be one or more of the items you mentioned, the alternator would lend to battery issues but it's the easiest to check with a volt meter.
It could also be: solenoid, ignition switch, starter relay, transmission range sensor or park/neutral switch.
When you say "I hear ittryingfor like 3 seconds" what does it sound like (i.e. clicking or grinding)?
Old May 15, 2007 | 05:19 PM
Hendge's Avatar
Hendge
It sounds more like grinding then ticking. I will listen more closely next time for a better description.
Thanks for the reply
Old May 15, 2007 | 05:45 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
If it was clicking or ticking I believe it would lend to a solenoid issue.
